1992 Honda Accord Radio Code Reset
LISAFMILTON
I recently had the battery replaced in my 1992 honda accord, but now I need to reset the code for the radio, and I do not know how to do this. It is a stick shift and is 2 wheel drive.
thanks
Jul 22, 2007 at 12:34 PM
BRUCE HUNT
  • 3,754 POSTS
Once the battery is disconnected the radio probably needs a code to allow its continued use. The code is a 5 digit code I believe. It is either is the manual with the car or if not, then you need the serials number of the radio and Honda will have to help you. Write the code down and store it in the glove box with the manual.
Jul 23, 2007 at 6:15 AM
Suggested Repair
After the battery is disconnected, the radio needs its five-digit code. Find the code in the owner's manual, or obtain it from Honda using the radio serial number. Write the code down and store it in the glove box with the manual.
Conversation Summary
The owner of a 1992 Honda Accord needs to reset the radio code after a battery replacement. The expert explains that the radio requires a five-digit code found in the owner's manual or available from Honda with the radio serial number, and recommends writing it down and storing it in the glove box.
