Car tries to start, but stumbles and shuts off
TOTALMC
  • 106 POSTS
Will do. Thanks.
Monday, July 13th, 2020 AT 8:06 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just to add my 2 cents there is something you need to know about Holley carburetors. Any time you have a backfire through the carburetor it blows the power valve and needs to be replaced. Even if you replace the valve and have another backfire it has to be replaced again. This is most likely the reason you car is running poorly. There is a conversion kit that is offered to prevent power valve damage in the event of a backfire.A hole is drilled in the primary metering block and a check ball and spring is installed. Hope this helps and thanks again for using 2CarPros.
Wednesday, July 15th, 2020 AT 6:22 AM
TOTALMC
  • 106 POSTS
But the problem has been intermittent, car has run great in between. It wouldn't have ran great if it had a blown power valve, right?
Wednesday, July 15th, 2020 AT 9:23 AM
  • 109,885 POSTS
I would think if the power valve was bad, it would not change. In other words, it wouldn't be good one time and not the next. However, he is correct about the backfire causing damage to it.
Have you had any progress with it?
Thursday, July 16th, 2020 AT 2:43 PM
TOTALMC
  • 106 POSTS
It backfired a bunch of times before I got the distributor right, but then ran great afterwards. Have not had a chance to test the coil or check the wiring yet.
Thursday, July 16th, 2020 AT 3:42 PM
  • 109,885 POSTS
Not a problem. Let me know what you find when you get to it.
Thursday, July 16th, 2020 AT 5:09 PM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, the performance would be affected by the power valve after a backfire. After getting things sorted out I would definitely change the power valve to improve performance from the carburetor. Keep us updated. Hope this helps and thanks again for using 2CarPros.
Danny-
Saturday, July 18th, 2020 AT 7:30 AM
Related Engine Not Running Content
