1991 Buick Regal Seat Belt Stuck
GMC
JIMMCCULLY
1991 Buick Regal around 50K for miles
I removed my driver’s side seat belt, (there are two mounts upper and lower on the door) to remove a broken door handle. That’s in and fixed. While I was doing that the seat belt went into the upper catch. So now if I mount the lower (with the male buckle that goes over lap) the top mount is hanging on top of the door in its loop. I cannot get it to release so I can mount it. Any ideas?
Apr 15, 2006 at 10:42 PM
LOSONE
  • 1,616 POSTS
If you can. remove the belt, open the plastic cover on the reel and click the little cog on the ratchet. That should do it. Good Luck
Apr 16, 2006 at 2:17 AM
Suggested Repair
Remove the seat belt, open the plastic cover on the reel, and click the small cog on the ratchet to release the belt so it can be remounted.
Conversation Summary
The owner of a 1991 Buick Regal removed the driver's seat belt to replace a broken door handle. After the handle was fixed, the belt retracted into the upper catch and would not release for remounting. The expert advised removing the belt, opening the plastic cover on the reel, and clicking the small cog on the ratchet to free it.
