1995 Buick Regal ABS Light On
5WOOD
My ABS brake light stays on. I think the left rear wheel speed sensor is faulty. Is it replaceable or built into the hub and the whole hub has to be replaced?
What is the procedure to replace my left rear wheel speed sensor?
Jul 11, 2007 at 3:18 AM
2CARPRO JACK
  • 11,533 POSTS
Yes, it is a hub assembly. Unbolt the old one and bolt in the new one, torque bolts to 52 ft. lbs.
Jul 12, 2007 at 1:06 AM
Suggested Repair
Replace the left rear wheel speed sensor as part of the hub assembly. Unbolt the old hub, install the new one, and torque the bolts to 52 ft-lbs.
Conversation Summary
The owner of a 1995 Buick Regal reported that the ABS light stays on and suspected a faulty left rear wheel speed sensor. They asked whether the sensor can be replaced separately or is built into the hub. The expert said it is a hub assembly and advised unbolting the old unit, bolting in the new one, and torquing the bolts to 52 ft-lbs.
