1995 Buick Regal coolant
2RKA
Other Category problem
1995 Buick Regal 6 cyl Front Wheel Drive Automatic 150k miles
i have to keep filling my resovour almost daily but i dont know were the coolant is going ? i check the oil but it looks good.
Dec 12, 2007 at 1:49 PM
  • 31,937 POSTS
Hi there, have the system pressure tested, there may be a small leak that is only evident under pressure, it also may be i a position that is only evident on a hoist. Have the coolant check for exhaust gasses, this is a simple chemical test that will show if a head gasket problem may be your trouble, Is there any excessive white smoke, or an unexpected miss fire , rough idle. this would also indicate a head problem>
Mark (mhpautos)
Dec 12, 2007 at 2:03 PM
