2002 Buick Regal Stuck in Park
GMC
DPERKINS
I have a 2002 Buick Regal that is currently locked in the park gear. It has been making a humming sound (like a plane or go kart) and just a few days ago I started it up but it would not move from the park gear. I tried the shift release lock and that did not work. Please advise.
Single Mom in desperate situation
Mar 17, 2006 at 2:59 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:619212144f="dperkins"]Hi,
Single Mom in desperate situation[/quote:619212144f]
A lot of vehicles require your foot ot be on the brake pedal to put the transmission in gear. The brake light switch is what links the two. Check the fuse for the brake lights and the switch itself.
Good luck and let us know. :)
Try posting in the GM section of the forum for more opinions.
Mar 17, 2006 at 12:23 PM
JPAM
  • 307 POSTS
bump**moved to GM forum
Mar 17, 2006 at 5:32 PM
Suggested Repair
Confirm the brake pedal is pressed when shifting out of park, then check the brake light fuse and the brake light switch that controls the shift interlock.
Conversation Summary
The owner of a 2002 Buick Regal says the vehicle is stuck in park, the manual shift release did not help, and it has been making a humming noise. An expert explains that the brake pedal must be pressed to shift and recommends checking the brake light fuse and brake light switch. The post was moved to the GM forum for more opinions.
