1994 Buick Regal Antenna Won't Retract Fix
HON KUDASAI
I have a '94 Buick Regal, with a power antenna, and a few days ago it just stopped retracting. When I turn the car or the radio on/off, I hear the antenna motor go off, but the antenna stays fully extended and won't move. How would I go about finding out what exactly broke, and how to replace it?
1994 Buick Regal, 74k miles, V-6 Engine
Aug 9, 2007 at 6:57 AM
DPWD23
  • 136 POSTS
The controll cable inside the antenna broke.
It is generally easier to find an after market power antenna (or manual one if you prefer) and install that, rather than trying to repair one. They are generally inexpensive, and are not complicated at all to install.
Aug 10, 2007 at 11:11 AM
Suggested Repair
The internal antenna control cable is broken. Replace the unit with an inexpensive aftermarket power antenna, or a manual antenna if preferred, rather than trying to repair the original.
Conversation Summary
The owner of a 1994 Buick Regal reports that the power antenna no longer retracts. The motor still runs when the car or radio is switched on or off, but the mast stays fully extended. The expert says the internal control cable broke and recommends installing an aftermarket power or manual antenna instead of repairing the original.
