1995 Buick Regal Brake Lights Out
MEDIADAVID
My brake lights only work when the the right turn signal is active. Otherwise, I get nothing. What might cause this?
Oct 3, 2007 at 2:54 AM
CLY
  • 308 POSTS
The brake light cucuit runs through the turnsignal switch assembly. The switch will need to be replaced to correct this condition.
Cly
Oct 12, 2007 at 10:24 PM
Suggested Repair
Replace the turn signal switch assembly, because the brake light circuit runs through it.
Conversation Summary
The owner of a 1995 Buick Regal reports that the brake lights work only when the right turn signal is active and otherwise do not come on. The expert explains that the brake light circuit runs through the turn signal switch assembly and recommends replacing the switch.
