1999 Buick Regal Soft Pedal and ABS Light
Suggested Repair
Have the ABS codes read with a GM-capable scan tool and perform a complete brake inspection for a hydraulic leak. Unplugging the ABS fuse can show whether pedal feel improves, but a soft pedal points more to a leak than an electrical ABS fault.
Conversation Summary
The owner of a Buick Regal reports the brake/parking brake light and ABS light are on, with a very soft, spongy brake pedal. Fluid was checked, the pads are worn but not badly, the ABS fuse looks good, and disconnecting the battery did not clear the lights. The expert asked whether the light is steady or flashing and whether it followed recent work, recommended reading GM ABS codes with the proper scan tool, and said a complete brake inspection is needed because the soft pedal sounds more like a leak than an ABS electrical problem.
