1990 Buick Regal Stalls When Braking
SMEAGOL
  • 5 POSTS
1990 regal Custom 3.1L, auto, 170,000 miles.
After the engine warms up if you apply the brakes its stalls. You can immediately restart the engine and it runs fine until you apply the brakes, it will stall.
Sep 24, 2007 at 7:04 AM
CLY
  • 308 POSTS
I would start by checking the valve to the brake booster.(big vaumm line) That elbow check valve should only let vacumm pull one way. Take it off and blow threw it and make sure that you can only blow air threw it in one direction. let me know results...
Cly
Sep 27, 2007 at 10:39 PM
Suggested Repair
Inspect the brake booster vacuum check valve on the large vacuum line. Remove the elbow valve and confirm it allows airflow in only one direction.
Conversation Summary
A 1990 Buick Regal with a 3.1L engine stalls after warming up whenever the brakes are applied, then restarts immediately and runs until the brakes are used again. The expert recommends checking the brake booster vacuum check valve to confirm it allows vacuum flow in only one direction.
