2002 Regal Light Problems
2002 BUICK REGAL
AJS525
  • 5 POSTS
2002 BUICK REGAL LS
3.8 L V6
150,000 MILES
My dash, odometer and tail lights do not work. I have checked all fuses and they seem to be fine.
Also, the warning chime that sounds when the door is opened and the headlamps are on is sounding even when the headlamps are off. The brake lights and Headlamps do work. Could this be a faulty headlamp switch?
Thanks,
Allen
Jul 17, 2007 at 11:39 AM
2CARPRO JACK
  • 11,533 POSTS
Very well could be. Need to remove switch to test for power out of it to the dimmer side for the dash lights
Jul 18, 2007 at 7:35 AM
AJS525
  • 5 POSTS
REPLACED TAIL LIGHTS AND STILL HAVE THE SAME PROBLEM. ANY OTHER SUGGESTIONS?
Aug 1, 2007 at 5:10 AM
2CARPRO JACK
  • 11,533 POSTS
Pull the headlight switch and test for power in and out with a test light
Aug 1, 2007 at 9:52 AM
AJS525
  • 5 POSTS
I miss spoke. I replaced the Headlight Switch with a brand new AC Delco part and still have the same problem
Aug 1, 2007 at 1:06 PM
2CARPRO JACK
  • 11,533 POSTS
Did you test the fuses with a test light?Did you test the fuses in the underhood power dist center? Do the front running lights work, but not the rear?
Aug 2, 2007 at 1:02 AM
AJS525
  • 5 POSTS
THE "TAIL LIGHT", "DIMMER" & "PARK LOCK" FUSES ARE NOT BLOWN BUT THERE IS NO POWER TO THE FUSE BLOCK. THE TEST LIGHT DOES NOT LIGHT. OTHER FUSES SEEM TO HAVE POWER
THE HEAD LIGHTS WORK WHEN SWITCHED ON MANUALLY. THE AUTOMATIC HEADLIGHTS DO NOT WORK. THE RUNNING LIGHTS AND TAIL LIGHTS STILL DO NOT WORK. ALSO, THE "HEADLIGHT LEFT ON" BELL STILL SOUNDS WHEN I OPEN THE DRIVERS DOOR EVENTHOUGH THE HEADLIGHTS ARE OFF.
JUST A REMINDER, I JUST INSTALLED A BRAND NEW AC DELCO "HEADLIGHT SWITCH" AND THAT DIDN'T FIX THE PROBLEM.
I WILL DONATE AGAIN TOMORROW.
THANKS FOR YOUR PATIENCE. :?:
Aug 2, 2007 at 12:04 PM
2CARPRO JACK
  • 11,533 POSTS
There are a few fuses in the underhood power center that feed th einterior fuse block, use a test light and check them.There are also some fusible links at the starter, test those with a test light as well.
Aug 3, 2007 at 12:52 AM
AJS525
  • 5 POSTS
I GIVE UP. THANKS FOR YOUR HELP.
Aug 4, 2007 at 4:04 AM
