1999 Buick Regal Warning Lights After Bump
BENNYLEROY
  • 10 POSTS
I have a 1999 buick regal 3.8 sometimes when I hit a bump in the road the all the warning lights go on (ie: traction cntrl, check engine, oil,low tire, ABS)the lights stay on until I shut the car off,after re-starting everything ifs fine.
Mar 3, 2007 at 4:22 AM
CHEVY22
  • 1,375 POSTS
sounds like there may be a loose connector at the cluster ,
Mar 3, 2007 at 7:47 AM
BENNYLEROY
  • 10 POSTS
[quote:f0052da4ed="CHEVYII"]sounds like there may be a loose connector at the cluster ,[/quote:f0052da4ed]what cluster? (ecm?)
Mar 3, 2007 at 7:51 AM
CHEVY22
  • 1,375 POSTS
oh im sorry , the gauge housing is called an instrument cluster
jim
Mar 3, 2007 at 8:11 AM
Suggested Repair
Inspect the instrument cluster (gauge housing) for a loose connector that may be disturbed when the car hits a bump.
Conversation Summary
A 1999 Buick Regal 3.8 sometimes illuminates multiple warning lights after hitting a bump, including traction control, check engine, oil, low tire, and ABS. The lights stay on until the car is shut off and restart normally afterward. The expert suggested a loose connector at the instrument cluster, also called the gauge housing, rather than the ECM.
