Oldsmobile Silhouette Codes 26 and 56
GMC
SUPERTIGRE
[code:1:726323f071]i check my oldsmobile silhouette,and i get 2 codes,56 and 26,one says 56 QDM 2 OR B ERROR
an the other one says 26 QDM 1 FAULT .
Do you know what they means ,what i have to check and how can i fix it.
thanks .
msupertigre.[/code:1:726323f071]
Mar 4, 2006 at 9:39 AM
MVANNESSJR
  • 223 POSTS
CODE 26
Trouble Code 26 indicates that the quad-driver is malfunctioning.
QDM symptoms:
Cooling fan(s) inoperative
Poor driveability due to 100% canister purge.
Coolant light "ON" all the time, "OFF" during bulb check.
EGR inoperative - Code 32.
TCC inoperative
This problem can be caused by:
1) Short to 12 volts on the control circuit by a shorted component.
2) Faulty ECM.
Mar 4, 2006 at 2:48 PM
Suggested Repair
For code 26, the quad-driver is malfunctioning. Check for a short to 12 volts on the control circuit from a shorted component, or test for a faulty ECM. Code 56 was not explained.
Conversation Summary
The owner of an Oldsmobile Silhouette reported codes 56 (QDM 2 or B error) and 26 (QDM 1 fault) and asked what they mean and how to fix them. The expert said code 26 indicates a malfunctioning quad-driver, listed related symptoms such as inoperative cooling fans, EGR, or TCC, and identified a short to 12 volts on the control circuit or a faulty ECM as possible causes. Code 56 was not addressed.
