1996 Chevy Monte Carlo Z34 Flasher
GMC
DIANAD
Where is the flasher box located on a 1996 Chevy Monte Carlo Z34? My signals and hazard lights don't work and I think it is the flasher. I have been looking all over under the dash. I have checked all the fuses which are good. Can you tell me where the flasher is located please? Thank you
Feb 24, 2006 at 10:57 AM
JPAM
  • 307 POSTS
The FLASHER RELAY should be with the other fuses.. thinking more so under the hood..
id go look at my 96 chev. lumina, but its setting in N. minnesota.. and im in bismark, nd going to reno, nv..
fun fun So take a look under the hood and there should be 2 boxes that have relays & fuses in them..
Should say on top of panels what is located in side of them.. Give me a reply back to see a far off i am..
thanks and happy hunting..
Feb 24, 2006 at 3:55 PM
MVANNESSJR
  • 223 POSTS
The flasher will be in one of the fuse blocks, either the interior or engine bay block. It will be a silver cylinder, it won't look like the other fuses and be much larger, about the size of a half dollar.
Feb 24, 2006 at 7:59 PM
Suggested Repair
Check the interior and under-hood fuse blocks for the flasher relay. It is a large silver cylinder, about the size of a half dollar, and does not look like the other fuses. The under-hood boxes should be labeled on their covers.
Conversation Summary
The owner of a 1996 Chevy Monte Carlo Z34 reports that the turn signals and hazard lights do not work and suspects the flasher after confirming the fuses are good. Experts say the flasher relay is in a fuse block, either under the dash or in the engine bay, and appears as a large silver cylinder rather than a standard fuse. The under-hood relay and fuse boxes should be labeled on their covers.
