1998 Chevrolet Monte Carlo Brake Lights
CHEVROLET
LYGREE
I have a 1998 Chevy Monte Carlo Z34 with 3.1L V6 and I keep having a problem with my brake lights. They do not always work. I have checked the bulbs and everything is fine. I noticed that they quit working when I use my turn signals. Then sometimes they start working again when I use the turn signal again. But I have tried it several times and this is not always the case. However, I did discover that if they are not working I can brighten or dim my headlights and and they will begin working immediately every time. I am assuming it is something to do with the turn signal switch. I would appreciate any help you guys could offer on this issue. :D
Jan 25, 2007 at 7:42 AM
SERVICE WRITER
  • 9,123 POSTS
The trun signal switch is what I was thinking as I read your post. Sometimes jiggling the switch from the lever or using the hazard button can get a reaction.
Jan 25, 2007 at 11:13 AM
LYGREE
I was told inthe past to try turning the hazzard switch on and off a few times and this seemed to help in the past. However, i am not getting the same results.
Jan 26, 2007 at 4:28 AM
SERVICE WRITER
  • 9,123 POSTS
Fair chance you'll need to get into it to test it, but I would be prepared and make sure one is readily available, don't want to have to put it back together if it needs it.
Jan 26, 2007 at 10:39 PM
Suggested Repair
Test the turn signal (multifunction) switch and have a replacement ready before disassembly, since it will likely need replacement if testing confirms the fault. Cycling the hazard switch previously helped but no longer does.
Conversation Summary
The owner of a 1998 Chevrolet Monte Carlo reports intermittent brake lights that stop working with the turn signals and immediately resume when the headlight dimmer is used. Bulbs were already checked. The expert agrees the turn signal switch is the likely cause and advises testing it with a replacement on hand so the steering column does not have to be reassembled if the switch is bad.
