2001 Chevy Monte Carlo Electrical Issues
JDCMJC
2001 chevy monte carlo has 52,000 miles on it and has a 3.8 engine. The radio locks up and the dimmer switch light doesn't light. The amp meter doesn't always work. The air conditioner does not work when this happens.
Apr 20, 2007 at 3:17 PM
GARFIELD
  • 197 POSTS
It sounds like you have a loose ground somewhere in your dash. If you have a manual for your car with an electrical schematic then look at all the problem areas and follow the ground wires back, bet they will all have a common point that they use for a ground. When you find that area is will normally be either loose connection or a dirty or corroded connection. Most automotive intermittent electrical problems can be traced down to either a loose or corroded connection. Hope this helps
Later
Gary
Apr 21, 2007 at 2:53 AM
Suggested Repair
Inspect the dash grounds for a shared connection that is loose, dirty, or corroded. Use an electrical schematic to trace the ground wires from the radio, dimmer, amp meter, and air conditioner back to that common point and clean or tighten the connection.
Conversation Summary
A 2001 Chevrolet Monte Carlo with a 3.8 engine and 52,000 miles has intermittent problems where the radio locks up, the dimmer switch light does not illuminate, the amp meter does not always work, and the air conditioner stops working at the same time. The expert suggested a loose dash ground and recommended tracing the related ground wires to a common point, then checking for a loose, dirty, or corroded connection.
