1998 Chevrolet Monte Carlo Soft Pedal Fix
Suggested Repair
Bleed the brake system to remove air that entered when the rear caliper piston came out. Fill the master cylinder, then bleed each wheel starting with the farthest from the master cylinder and working toward the front. Have a helper pump and hold the pedal while you crack each bleeder until only fluid comes out, and keep the master cylinder full throughout.
Conversation Summary
The owner of a 1998 Chevrolet Monte Carlo Z34 replaced the rear pads. The rear-left caliper piston came out too far and was pushed back in. Afterward the pedal was very soft, stopping power was poor, and the front-right and rear-left brakes stayed cold. The expert explained that air entered the system and must be bled out at each wheel, starting farthest from the master cylinder, while keeping the reservoir full.
