rear wiper motor
RDMOULDS
I have a 1998 jimmy 4 door with 110,500 miles with the V-6. The rear wiper motor does not move and I want to know how do you go about removing said motor. The swicth is fine. Is the plastic cover on the tailgate just snapped in? If so then getting to the motor should be easy. How do you get it out.
Sep 27, 2007 at 2:49 PM
BMRFIXIT
  • 19,053 POSTS
[quote:040d216d10="rdmoulds"]I have a 1998 jimmy 4 door with 110,500 miles with the V-6. The rear wiper motor does not move and I want to know how do you go about removing said motor. The swicth is fine. Is the plastic cover on the tailgate just snapped in? If so then getting to the motor should be easy. How do you get it out.[/quote:040d216d10]
it has few screws look for them and the handle
plastic off
outside at the botttom of the wiper remve nut pull wiper arm out
3 mouting bolts for the motor
good luck
let us know
Sep 27, 2007 at 2:59 PM
