1988 GMC Jimmy Oil Pan Removal
MJWIDD
  • 12 POSTS
1988 Gmc Jimmy 4x4 2.8L
Do I have to drop the front pumpkin in order to remove the oil pan. Any tips or Help would be appreciated.
Apr 4, 2006 at 11:37 AM
PEPPERMRJ
  • 1,158 POSTS
It is possible but you do have to remove the steering linkage assembly, the forward drive axle and crossmember (4WD) and/or the engine mounts.
Best to pull the engine, quicker.
Good luck and let us know. :)
Apr 4, 2006 at 2:49 PM
Suggested Repair
Oil pan removal on this 4WD may be done without dropping the front differential, but the steering linkage, forward drive axle, crossmember, and/or engine mounts must be removed. Pulling the engine is often quicker.
Conversation Summary
The owner of a 1988 GMC Jimmy 4x4 with a 2.8L engine asked whether the front differential must be dropped to remove the oil pan. The expert said removal is possible without that, but the steering linkage assembly, forward drive axle, crossmember, and/or engine mounts must come off, and pulling the engine is quicker.
