1998 GMC Jimmy Rear Wiper Motor Removal Fix
RDMOULDS
I have a 1998 jimmy 4 door with 110,500 miles with the V-6. The rear wiper motor does not move and I want to know how do you go about removing said motor. The swicth is fine. Is the plastic cover on the tailgate just snapped in? If so then getting to the motor should be easy. How do you get it out.
Sep 27, 2007 at 2:49 PM
BMRFIXIT
  • 19,053 POSTS
[quote:040d216d10="rdmoulds"]I have a 1998 jimmy 4 door with 110,500 miles with the V-6. The rear wiper motor does not move and I want to know how do you go about removing said motor. The swicth is fine. Is the plastic cover on the tailgate just snapped in? If so then getting to the motor should be easy. How do you get it out.[/quote:040d216d10]
it has few screws look for them and the handle
plastic off
outside at the botttom of the wiper remve nut pull wiper arm out
3 mouting bolts for the motor
good luck
let us know
Sep 27, 2007 at 2:59 PM
Suggested Repair
Remove the tailgate plastic cover by locating its screws and the handle, then take the cover off. Outside, remove the nut at the bottom of the wiper, pull the wiper arm off, and remove the three motor mounting bolts.
Conversation Summary
The owner of a 1998 GMC Jimmy says the rear wiper motor does not move even though the switch is fine, and asks how to remove the motor and whether the tailgate plastic cover just snaps in. The expert says the cover is held by a few screws, then the exterior wiper-arm nut should be removed, the arm pulled off, and the three motor mounting bolts removed.
