1996 GMC Jimmy Broken Door Mirror Fix
MDECENZO
The vehicle is a 1996 GMC Jimmy 4 dr. SLT 4X4 with power mirrors. The question is the mirror is broken off at the base how do I go about removing the old and replaceing with a new one.
Many thanks for your help.
Oct 15, 2007 at 8:53 AM
MERLIN2021
  • 17,250 POSTS
Probably requires the removal of the door panel, then unscrew it from the inside, Get the tool for the clips, If you don't you will break the door panel!
Oct 15, 2007 at 8:55 AM
Suggested Repair
Remove the door panel using a proper clip tool so the panel is not damaged, then unscrew the broken mirror from the inside and install the replacement.
Conversation Summary
The owner of a 1996 GMC Jimmy with power mirrors asked how to remove and replace a driver-side mirror broken off at the base. The expert said the door panel likely must be removed, the mirror unscrewed from inside, and a clip tool used to avoid breaking the panel.
