1995 GMC Jimmy Blower Motor Intermittent
KAYKAY
The blower moter on my 1995 jimmy works fine the first start of the day, after the vehicle is shut off the first time it is hit or miss as to whether it will work for the rest of the day. (Makes no difference if it has run for 2 mins or 2 hours.) The dash switch has been relaced trying to deal with this but did not help. Also where is the location of the blower moter?
Jan 25, 2006 at 4:06 AM
SC1 RACING
  • 117 POSTS
the blower motor is located below the glove box. it will have a circle shape on the cover.
mine does that, and has done this for over a year. it is more than likely a bad connection. if mine doesnt work i "kick start it" its one of those things i cant find time to fix for myself... :lol:
Jan 25, 2006 at 4:15 AM
Suggested Repair
The blower motor is below the glove box under a circular cover. The intermittent operation is most likely a bad electrical connection, so inspect and repair that connection.
Conversation Summary
The owner of a 1995 Jimmy said the blower motor works on the first start of the day but may not work after the vehicle is shut off, regardless of how long it ran. Replacing the dash switch did not help, and the owner asked where the motor is located. The expert said it is below the glove box under a circular cover and that the problem is most likely a bad connection.
