1997 GMC Jimmy Blower Motor Replacement Fix
BABYEBK
  • 6 POSTS
97 gmc jimmy my blower motor is bad for the ac and heater and i wonder if it is an easy job to do or if i should have a mechanic do it for me if it is easy what are the steps
Jun 10, 2007 at 11:26 AM
  • 75,988 POSTS
[quote:06b56c5cec="babyebk"]97 gmc jimmy my blower motor is bad for the ac and heater and i wonder if it is an easy job to do or if i should have a mechanic do it for me if it is easy what are the steps[/quote:06b56c5cec]
Disconnect negative cable.Remove vehicle control module(If equipped).Remove coolant reservoir and cooling tubes,unplug connector and remove blower motor.
Jun 11, 2007 at 9:54 AM
Suggested Repair
Disconnect the negative battery cable. Remove the vehicle control module if equipped, then remove the coolant reservoir and cooling tubes. Unplug the connector and remove the blower motor.
Conversation Summary
The owner of a 1997 GMC Jimmy asked whether replacing a failed heater and AC blower motor is an easy DIY job and what the steps are. The expert advised disconnecting the negative battery cable, removing the vehicle control module if equipped, removing the coolant reservoir and cooling tubes, unplugging the connector, and removing the blower motor.
