Replacing an Automotive HVAC System Blower Fan Motor - 2CarPros
automotive blower motor replacement
Fan blower motor not working? This guide will walk you though a typical HVAC blower motor replacement step by step and will also show you what you are paying for when taking your car in for repairs.
Tools and Parts You'll Need
  • Socket set (commonly 8mm, 10mm sockets)
  • Screwdrivers (both flathead and Phillips)
  • Torx drivers (if required by your vehicle)
  • Trim removal tool
  • Flashlight or work light
  • Gloves
  • Safety glasses
  • Replacement blower motor
  • Blower motor resistor (if needed)
Let's Get Started!
The blower motor can be located in one of two places which is under the dashboard or hood on the passenger side of the vehicle. The blower motor is continuously used for all climate control modes including: air conditioner, heater, fresh air and defroster. Accessing a blower motor can be difficult or extremely simply depending on the manufacturers design.
Accessing the Blower Motor
1. Start by checking under the hood and looking around the passenger's side for something that looks like this:
under hood blower motor
2. If you cannot find the blower motor under the hood it will be located under the dash on the passenger side. You may need to remove the mounting screws of the lower trim panel to gain access to the motor for removal.
lower cover
3. This heater motor location is under the dash. Let's start the removal which is the same for under hood or dash applications as well.
blower motor with wiring
Remove the Blower Motor
4. Locate and disconnect the HVAC system blower motor wiring by releasing the safety tab on the side of the connector. This connector can have one or four wires depending if the system is manually or automatically controlled. These different systems will vary the fan speed by using a solid state speed controller apposed to a basic speed resistor.
5. Once the electrical connector is removed check its condition while looking for corrosion or burned terminals which are a sign of high resistance or increased amperage draw. If the connector is melted it must be replaced by splicing in a new part which you can get from the dealer, auto parts store or Amazon. Opposed to a crimp connector, it's best to solider these wires together to cut down on resistance which helps the motor last longer.
disconnect blower fan wiring connector
6. Identify the blower motor and the mounting screws holding it into the heater box (plenum). These screws are mounted in the plastic housing and are not to terribly tight so they can be removed easily. Some of these screws can be hidden under metal braces, plastic tabs or wiring so use a small mirror if needed.
small mirror to find screws
7. Start by removing the mounting screws one at a time. The motor will then start to fall out of the heater box. While holding the blower motor in place remove the last screw.
remove blower motor mounting screws
8. After all of the screws have been undone grasp the motor and remove it from the housing. This can take some maneuvering so hang in there and be careful not to damage the fan blade (squirrel cage) against the heater plenum case.
blower motor removed
Install the New Blower Motor
9. Once the old motor has been removed compare it to the new unit. In some cases an electronic speed controller is used in climate controlled systems and will need to be transferred to the new motor, but this is not typical. On some replacement units you will need to transfer the old fan blade over to the new assembly. This is done by removing the mounting nut or clip and then forcing the blade off of the motor shaft using a large standard screwdriver. Do not use oil or lube of any kind to help installation of the fan onto the replacement motor because it will allow the fan to slip on the shaft which will create problems.
new blower fan motor
10. Before installing the new motor into the plenum check for obvious obstructions such as leaves, sticks, ink pens, tooth picks or small toys which can get into the system via the inlet or outlet vents. These foreign partials can keep the motor from working freely and could cause premature failure. When the new assembly is ready to be installed fit the motor by maneuvering and rotating it gently. Then push it back into the plenum while lining up the mounting holes.
installing new blower motor
11. While the motor is in place start to install the mounting screws while holding it toward the plenum. Do not tighten any of the screws until all screws have been threaded in by hand. This will make the installation go mush easier without the potential of stripping the screws out. Tighten each screw in a cross pattern, do not over tighten. This will ensure the proper alignment of the fan blade in the housing. If this step is not done properly it can cause the blade to contact the housing creating a rubbing or clicking noise when the motor is operating.
installing blower motor screws
12. Check the wiring connector locating tang which indicates the orientation of the connector before it's installed into the motor. This tang is to ensure you don't install the connector incorrectly which would cause electrical problems.
inspect blower fan motor connector
13. Carefully re-insert the blower fan motor electrical connector by securing it into position, you should hear an audible click telling you the connector is installed correctly. Gently tug on the wiring to ensure its correct installation. Then reinstall the lower dash cover and install the mounting screws by hand. Tighten them snuggly, do not over tighten, again these screws are going into plastic.
reinstall blower fan motor wiring connector
Finally start the engine up and turn the climate control on and listen for the fan to come on. It should sound smooth and be blowing from the vents in a strong flow. If you hear a rattle, squeak or ticking turn the system off and remove the blower motor to recheck the installation.
Watch the Video!
Please watch this video of the job being done to glean additional helpful information.
Credits
This guide knowledge base was created by the 2CarPros Team. If you have a car repair question, you can ask the 2CarPros community for help. Please visit our 2CarPros YouTube Channel for more helpful repair videos.
Repair Safety Notice: This guide is provided for general informational and educational purposes only. Vehicle repairs can involve risk of injury, property damage, or vehicle damage. Always follow proper safety procedures, use the correct tools, support the vehicle securely when raised, and consult a qualified automotive repair professional if you are unsure about any step.
