1994 GMC Jimmy Catalytic Converter Test
CONVICTSTEEL
1994 gmc jimmy v6 vortec vin#w 2wd 4 door automatic trans fuel injected
is there a way to test a catalytic converter on this truck
May 2, 2007 at 8:22 AM
SERVICE WRITER
  • 9,123 POSTS
If your checking for a flow problem, you can rap on the bottom of it and listen to see if it is broken interanlly, or drop the fornt pipe engough so that the exhaust flow is not flowing through the pipes and drive it to see if there is the lask of power still present...if that is the complaint.
May 2, 2007 at 11:46 AM
Suggested Repair
Tap the catalytic converter and listen for internal breakage. If the complaint is lack of power, loosen the front exhaust pipe so exhaust bypasses the converter and test-drive to see whether the power loss remains.
Conversation Summary
The owner of a 1994 GMC Jimmy asked how to test the catalytic converter. The expert suggested tapping the converter to check for internal breakage, or dropping the front pipe so exhaust bypasses it and driving to see whether a power complaint remains.
