Gauge cluster swap now no start condition
STATE0303
  • 2002 DODGE RAM
  • 5.9L
  • V8
  • 4WD
  • 290,000 MILES
I put a 2005 gauge cluster in 2002 Dodge Ram. Now I have no gauges at all. It was clicking I unplugged it and put original back in. Now I only have four ways and it does not start, nothing.
Monday, April 8th, 2019 AT 6:14 PM
Hi State0303,
Instrument clusters used in this vehicle automatically configure themselves for compatibility with the features and optional equipment in the vehicle in which they are initially installed. The instrument cluster is programmed to do this by embedding the Vehicle Identification Number (VIN) and other information critical to proper cluster operation into electronic memory. This embedded information is learned through electronic messages received from other electronic modules in the vehicle over the Controller Area Network (CAN) data bus, and through certain hard wired inputs received when the cluster is connected to the vehicle electrically. Once configured, the instrument cluster memory may be damaged and irreversible configuration errors may occur if the cluster is connected electrically to another vehicle or, if an electronic module from another vehicle is connected that provides data to the instrument cluster (including odometer values) that conflicts with that which was previously learned and stored. Therefore, the practice of exchanging (swapping) instrument clusters and other electronic modules in this vehicle with those removed from another vehicle must always be avoided.
When you get a replacement instrument cluster, they are provided with the correct VIN, and the certified odometer and engine hours values embedded into cluster memory, but will otherwise be automatically configured for compatibility with the vehicle it is plugged into.
Unfortunately, it sounds like you need to get a replacement cluster that has the correct information programmed into it.
Let me know if you need more info. Thanks
Kenny.
Tuesday, April 9th, 2019 AT 8:11 PM
