When I try to start the engine, it turns over and will try to start but then idles very slowly and erratically for a second or two and then eventually dies out. Sometimes it will only turn over without starting at all. When it does this I've sprayed starting fluid into it and it starts immediately, but then dies again. It seems to me like it could be a fuel problem. I believe (although I am not sure) that a 2002 Dodge Ram does not have a fuel filter. So, should I start off by replacing the fuel pump and is it located in the tank, or are there some other avenues I should try first?
Any help or advice is greatly appreciated.
-Thanks!
SPONSORED LINKS
Saturday, March 15th, 2008 AT 12:53 PM
