As far as the pressure, 3-6 psi should be okay. That leaves either the float is set too high, or the needle and seat is worn. Either of these two things would have to be minimal/slightly out of adjustment or worn since the issue is at idle.
Have you had the carb apart for inspection?
Was this helpful?
Friday, May 31st, 2024 AT 8:31 PM
