Fuel gauge reads empty all the time
MARK COCHRAN
  • 16 POSTS
Diagram I have for the cluster says #2 pin fused B+, #6 pin panel lamps driver, #9 pin CCD BUS -, #10 pin CCD BUS +, #11 pin fused ignition switch output. Almost ready to order BCM and drop tank back down to check float. Will check BCM pin 46 first and get back with you on that. More gray hairs!
Thursday, August 29th, 2019 AT 7:18 PM
  • 110,182 POSTS
Welcome back:
At least you have hair to turn gray. LOL I've done this long enough that, well, not too much left.
Thursday, August 29th, 2019 AT 8:11 PM
MARK COCHRAN
  • 16 POSTS
At wits end. I applied 2.5 volts directly to the cluster.. Pins 9 and 10. Positive and negative and the gauge didn't move. So I thought if it is bad can't hurt to apply same voltage directly to the gauge. Jogging between the four pins on back of gauge. Still nothing? I have ordered a used one that is warranted to work and for 6 months, . But still unsure of what is wrong. Help!
Sunday, September 1st, 2019 AT 3:15 AM
  • 110,182 POSTS
Welcome back:
If you applied power and it didn't respond, it does sound like it is bad. I would be trying the same thing you are doing to see if it is the cluster.
Let me know if it fixes the issue.
Sunday, September 1st, 2019 AT 5:49 PM
