SELF-DIAGNOSTICS
With ignition off, press and hold TRIP and RESET buttons while turning ignition switch to ON
position. Continue to hold TRIP and RESET buttons until odometer window displays CODE
(approximately 5 seconds). If problem exists, system will display diagnostic trouble codes. See
DIAGNOSTIC CODE CHART table. If no problem exists, Code 999 (end test) will be displayed.
Code Description
11 Cluster Calibration Fault
110 Cluster Memory Fault
905 No CCD Bus Message From TCM
921 Odometer Fault From BCM
940 No CCD Bus Message From PCM
© 2008
SPONSORED LINKS
Thursday, February 25th, 2010 AT 6:35 PM
