1998 Ford Explorer Cold Start Valve Noise
KNDXFD11
i have a 1998 ford explore v-6 65,000 miles
when it is cold the vaules make a loud noise upon starting up maybe last about afew seconds then it
stop. could this be my oilpump going bad or need
lifters.
May 16, 2007 at 7:39 PM
  • 75,988 POSTS
[quote:21fff95507="kndxfd11"]i have a 1998 ford explore v-6 65,000 miles
lifters.[/quote:21fff95507]
Sounds like lifters leakdown problem-shows up on initial start-up and disappears within a few secs.
An oil change won't hurt with a thicker oil or just lifters replacement.
May 16, 2007 at 9:48 PM
Suggested Repair
Treat the brief cold-start noise as lifter leakdown. An oil change with thicker oil may help; otherwise replace the lifters.
Conversation Summary
The owner of a 1998 Ford Explorer V6 with 65,000 miles reports a loud valve noise for a few seconds on cold start that then stops, and asks whether the oil pump or lifters are failing. The expert attributes it to lifter leakdown and suggests a thicker oil change or lifter replacement.
