1999 Ford Explorer Rough Cold Start
KEITH SMITH
1999 Explorer Sport, 4.0 SOHC V-6 108,000 miles. After sitting overnight or for long periods of time, vehicle runs very rough at start up, high to low idle and occasionally dies. Problem goes away after engine warms up. Shows the code for lean bank 1 and 2. Had it diagnosed at a recommended shop that said it was definitely the MAF. I replaced this and it didn't help at all. THey said they tested the intake manifold gaskets, but I have no proof. I've also replaced fuel filter and plugs. Air filter looks clean. Any help on where to turn next is appreciated.
Nov 23, 2006 at 12:54 PM
BRUCE HUNT
  • 3,754 POSTS
Coming from a Honda forum to assist, try these thoughts. The intake manifold will usually cause the surging of the engine to be a constant thing. But air in the cooling system can cause problems. Also, you must have something like an Idle air control and it could be plugged.
Nov 23, 2006 at 1:34 PM
AARON
I also have the same issue. I have a 02 Explorer Sport Trac. It idles hi to low and dies. But when warmed up runs fine. Called the ford dealer, wanted 100 bux to hook to a computer but told me sounds like a Idler Air Control valve. They wanted 300 bux to fix. Bought the valve at Autozone for 75. But did not fix the problem. I googled the same question, majority of the responses had "coil on the plug bad?" Let me know if you have any luck.
Dec 5, 2006 at 6:47 PM
CARUNDELL
  • 602 POSTS
Hey Keith,
Bruce has you pointed in the right direction and its a common ford issue, with the "plastic" intakes. The seals (not gaskets) fail and when cold don't seal, when hot everything expands and it seals. Its not to terrible of a job for the avid DIYer, and you can get the seal kit from ford for cheap money!
Regards,
Chris
Dec 5, 2006 at 8:50 PM
AARON
Have also did the fuel filter and new air filter, no dice. Chris so you think the seal kit would fix the issue? Mine starts good RPM's up to about 2k and when sinks back down you'd think the engine is getting strangled with all the spittin and sputtering it goes through! If I don't sit in the truck and hit the gas when it almost dies, it will..... This has also happened a few times when its warm then go to the bank drive thru for ex. its died!
Dec 5, 2006 at 10:08 PM
CARUNDELL
  • 602 POSTS
[quote:ac044df89e="aaron"]Have also did the fuel filter and new air filter, no dice. Chris so you think the seal kit would fix the issue? Mine starts good RPM's up to about 2k and when sinks back down you'd think the engine is getting strangled with all the spittin and sputtering it goes through! If I don't sit in the truck and hit the gas when it almost dies, it will..... This has also happened a few times when its warm then go to the bank drive thru for ex. its died![/quote:ac044df89e]
Hey aaron
Please bear in mind that its very hard to diagnose an issue with out being right there in front of the vehicle, but given the history and symptoms of the vehicle I would say yes, the vacuum leaks @ the intake will cause the IAC to act erratically as the PCM is trying to compensate for the additional "air" coming in (simplified) Second, the p0170's codes point me in that direction too as it indicates both banks are lean.
Having said that, there are also issues w/ the MAF causing p0170's codes and even if the MAF specs out ok. Additionally, there are also IAC issues too but they usually pop a code and its pretty obvious.
You need special equip to nail the diagnosis though, be able to graph the O2 on a scanner or labscope and some carb cleaner sprayed on the intake mating surfaces is my favorite quicky test for an intake seal test. Do it when its cold and spray the carb clean and "watch" the O2 go fixed rich and your pretty much done
I would have to recommend taking the vehicle to a trusted shop and get it diagnosed properly.
Anyone else out there got any good quicky tests??? hope this helps!!!
Regards,
Chris
Dec 5, 2006 at 10:31 PM
AARON
Thanks Chris appreciate the help!
Dec 5, 2006 at 11:11 PM
CARUNDELL
  • 602 POSTS
My pleasure! Glad to help!!
Chris
Dec 5, 2006 at 11:17 PM
Suggested Repair
Have the plastic intake manifold seals checked, especially when cold. A vacuum leak there can make both banks lean and cause the idle air control to surge until the engine warms and the seals expand. Confirm with a cold spray test while watching the oxygen sensors, and have a shop verify before replacing parts, since a faulty MAF or idle air control valve can cause similar symptoms.
Conversation Summary
A 1999 Ford Explorer Sport runs rough, surges, and sometimes dies after sitting, then runs normally once warm, with lean codes on both banks. The MAF, fuel filter, and plugs were already replaced without success. A second owner reported the same cold idle problem on a 2002 Explorer Sport Trac after replacing the idle air control valve. Experts said failing plastic intake seals are a common Ford cause and recommended a proper cold diagnostic test rather than more parts guessing.
