1991 Ford Explorer No-Start After Running
Suggested Repair
Confirm spark when the no-start occurs. If there is no spark, check primary voltage at the coil; voltage with no spark points to a bad coil, while no voltage points to the ignition module or crank sensor. If spark is present and the engine stalls as if starved of fuel, inspect fuel hoses and connections, check the fuel filter under the vehicle near the driver's seat, and measure fuel-rail pressure at the Schrader valve; it should be 30 to 45 PSI.
Conversation Summary
A 1991 Ford Explorer 4.0L runs well but, after repeated starts, cranks without starting or starts and stalls until it sits briefly. The expert ruled out the voltage regulator and advised testing spark, coil primary voltage, the ignition module, and the crank sensor near the harmonic balancer. After the owner confirmed spark and suspected fuel delivery, the expert recommended inspecting fuel lines, checking the filter under the vehicle, and measuring 30 to 45 PSI at the fuel-rail Schrader valve.
