1999 Ford Explorer Stalls Off Idle
RENEEWIGFALL
ford explorer 1999... 99,887...v6?
My car will sound like it is going to start and then cut off.....if i turn the key and keep my foot on the gas it will run until i let up off the gas....Can you tell me what type of problem this could be?
Feb 15, 2007 at 9:13 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a vacuum leak. Has the engine backfired lately? sometimes they will blow vacuum lines off the intake when that happens.When I say backfire I mean chugs like when it isnt cranked long enough to really start and kinda burps.Look around under the hood for a clean fitting on the intake, that would be where the line was
Feb 15, 2007 at 11:52 PM
RENEEWIGFALL
I haven't heard any backfiring....could it be the IAC valve?
Feb 16, 2007 at 1:05 AM
2CARPRO JACK
  • 11,533 POSTS
If there arent any vacuum leaks, yes it could
Feb 16, 2007 at 2:23 AM
Suggested Repair
Inspect for vacuum leaks, including a vacuum line that may have blown off the intake. If no leaks are found, test the IAC valve.
Conversation Summary
A 1999 Ford Explorer V6 sounds like it will start, then cuts off, but will keep running if the gas pedal is held. The expert suggested a possible vacuum leak and advised looking for a disconnected line at the intake. The owner reported no backfiring and asked about the IAC valve; the expert said that could be the cause if no vacuum leaks are present.
