1995 Ford Explorer Cranks But Won't Start
RUSSFIELDING
My 1995 Ford Explorer--4.0L V6 with 195k miles--won't start. The problem is not with the battery or starter--it cranks and cranks but won't start. Either gas or spark is not getting to the engine. What is the best (cheapest) way to diagnose this problem? My plan of action for now is to test for a spark and then replace the fuel filter. After that, I guess I could try to replace the fuel pump. Suggestions?
Also, how do you test for a spark besides just pulling a spark plug and watching it while someone else turns the key?
Thanks!
Apr 11, 2007 at 11:57 AM
BACKYARDMECHANIC
  • 337 POSTS
Before replacing any parts you might want to see if you have a fuel or ignition problem. You can make a few checks to narrow it down. First check for spark as you have planned. As far as making the test the only way I know ( without a tester) is to use a screw driver placed into the end of the the plug wiring. Make sure you are holding the handle of the screw driver if you don't want to get a shock. If no spark then you will have to trouble shoot the ignition system. You can check to see if the fuel pump is running with help from an assistant. Have the assistant listen next to the fuel tank, while you turn the ignition key to the on postion. If the pump is running you should hear it humming. This dosen't mean the pump is mechanical good just the electrical part. (fuse relay, wiring etc). IF you have a fuel pressure tester you can test for proper fuel pressure which will verify that the pump is either good or bad.
Apr 11, 2007 at 12:23 PM
Suggested Repair
Before replacing parts, check for spark at a plug wire and listen at the fuel tank for the pump when the key is turned on. If there is no spark, troubleshoot the ignition system. Use a fuel pressure tester to confirm whether the pump is delivering proper pressure.
Conversation Summary
The owner of a 1995 Ford Explorer 4.0L says it cranks but will not start and suspects missing fuel or spark. The expert advises checking spark first, listening near the tank for the fuel pump with the key on, and testing fuel pressure before replacing the filter or pump.
