1996 Ford Explorer Won't Start
HOTRODCALVERT
I just recently bought a 1996 Ford Explorer XLT. It has a 5.0 V8, 167,000 miles, automatic, fully loaded. It ran fine for the 1st 2 weeks I had it, then one morning it wouldn't start. I listened closely; the fuel pump wasn't kicking on. If you would give it a few hours and try it again, it would start right up. This persisted until I finally got fed up and had the fuel pump replaced. Same thing happened afterwards. So I had the fuel pump relay and fuel filter changed. Same thing happened once again. I took it to an auto shop and they tinkered with it. To my amazement, the mechanic turned the key forward (the pump didnt kick on of course), but when he started tapping on the fuse box under the hood, the pump kicked on and it started right up. Do I have an electrical issue?
Aug 11, 2007 at 12:48 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a bad connection in the box.Disconnect the neg battery cable, remove th ebox enought o open the bottom and look for corrosion or loose connections
Aug 12, 2007 at 1:54 AM
Suggested Repair
Disconnect the negative battery cable, open the underhood fuse box from the bottom, and inspect for corrosion or loose connections.
Conversation Summary
The owner of a 1996 Ford Explorer had an intermittent no-start because the fuel pump would not prime. Replacing the pump, relay, and filter did not help. A mechanic found that tapping the underhood fuse box made the pump run. The expert advised disconnecting the negative battery cable and checking that box for corrosion or loose connections.
