1969 Ford Mustang Won't Shut Off
HAMILTON
I have a 1969 Ford Mustand Grande, with a 302 engine, automatic transmission and factory air...service regularly, tune up two weeks ago, new alternator and generator in last 3 years.....about 40,000 miles on a rebuilt engine
Yesterday, I turned the engine off. Decided to repark the car, and turned it back on....moved it a few feet....and it started racing....key would not turn engine off -- ignition moved to all three positions accessesory and on....and off....would not turn off car....high noise level like screeching metal on metal
Decided to drive it around.....went about 1/2 block still would not turn off....drove 1/2 mile....noticed none of the dash gauges...speedometer or gas gauges were working.....engine began to sound normal no screeching.....pulled car over....STILL COULD NOT TURN IT OFF.....after idlying in park.for about a minute...it just turned it SELF OFF...and would not start again...
any suggestions?
Jun 7, 2007 at 12:49 AM
MERLIN2021
  • 17,250 POSTS
You have a short cicuit in the ignition cicuit! Could be the switch, as for the racing engine, could be a bad accelerator cable, seems like a lot to go wrong at the same time!, but it's 40 years old!
Jun 7, 2007 at 8:55 AM
Suggested Repair
Check the ignition circuit for a short, including the ignition switch. Also inspect the accelerator cable for binding that could cause the engine to race.
Conversation Summary
The owner of a 1969 Ford Mustang Grande with a 302 engine said the engine raced, would not shut off with the key in any position, and the gauges stopped working before it shut itself off and would not restart. The expert attributed the no-shutoff condition to a short in the ignition circuit, possibly the ignition switch, and suggested a faulty accelerator cable as a possible cause of the racing.
