1989 Ford Mustang Cranks With Key Off
MUSTANG89
1989 Ford Mustang Lx / 125,000 miles (ya ya its old) / 5.0 liter. I went to start my car the other day and it was dead. I decided to buy a new battery with the cable cleaning kit and the foam spacers. I put the battery in first connecting the ground and then when i went to connect the power cable the car tried to start. At this time there was no keys in the ignition and the car was turned off. So now im stuck with a car that tries to start itself when hooking up a new battery.
Jun 28, 2007 at 12:05 AM
MIKE H R
  • 3,094 POSTS
try putting the key in the ignition in the on position, and in part. Have someone turn the key on and off as you touch the positive side on the battery. If the vehicle still continues to turn over you have a problem with the ignition switch.
Jun 28, 2007 at 1:46 AM
98RANGERXLT
  • 301 POSTS
Some of the older cars the starter solenoid would stick when this happens rap on the starter solinoid a few times and try it .
Jun 28, 2007 at 12:43 PM
MUSTANG89
[quote:520e1a8be8="Fordman16"]Some of the older cars the starter solenoid would stick when this happens rap on the starter solinoid a few times and try it .[/quote:520e1a8be8]
You're the man fordman fixed it right up i really appreciate everyones help.
Jun 30, 2007 at 2:20 PM
98RANGERXLT
  • 301 POSTS
Your welcome
Jun 30, 2007 at 3:39 PM
MERLIN2021
  • 17,250 POSTS
Also when you do ANYTHING to the electrical, hook up ground last!!! And disconnect first.
Jul 1, 2007 at 6:06 AM
Suggested Repair
Tap the starter solenoid a few times if it sticks and the engine cranks when the positive battery cable is connected with the key off. If it still cranks while the key is cycled, check the ignition switch. Always connect the ground cable last and disconnect it first.
Conversation Summary
A 1989 Ford Mustang LX with a 5.0L engine tried to crank when the positive battery cable was connected, even though the key was out and the ignition was off. One reply suggested checking the ignition switch by cycling the key while connecting the cable. Another suggested tapping a sticking starter solenoid, which the owner confirmed fixed the problem. A final note advised connecting the ground cable last and disconnecting it first during electrical work.
