1999 Ford Windstar Battery Won't Charge
JSKINNER
  • 6 POSTS
I have a 1999 Ford Windstar and the battery went dead last week and I bought a new one but the battery light came on still and died again a few hours later. So I replaced the cables and the ground wire. That still didn't work so I replaced the alternator. That didn't work either it will run for a few minutes after charging the battery but will not hold a charge off a jump start.
Mar 3, 2007 at 9:07 AM
BHUGG
  • 157 POSTS
first I would check the Power distribution box under the hood. This box has fuses and relays in it. Don't confuse it with the fuse box in the dash. But check the one in the dash as well.
Look for a blown fuse. If the fuses are good, then check the wires that go from the alternator to the starter relay. There is a fusable link in it. It may not be obvious where it is. Check it out with an ohmmeter.
Good luck.
Let me know how it turns out.
If we on line help your situation, vote for us.
Mar 3, 2007 at 5:08 PM
Suggested Repair
Check the underhood power distribution box and the dash fuse box for blown fuses or bad relays. If the fuses are good, test the wires from the alternator to the starter relay, including the fusible link, with an ohmmeter.
Conversation Summary
A 1999 Ford Windstar battery went dead, and replacing the battery, cables, ground wire, and alternator did not fix it. The van runs briefly after charging but will not hold a charge after a jump, and the battery light stays on. The expert advised checking fuses and relays in the underhood power distribution box and dash fuse box, then testing the alternator-to-starter-relay wiring and fusible link with an ohmmeter.
