1999 Ford Windstar Battery Light On
VGOOSE
My alternator died, once i had replaced it and the battery the warning light stayed on . I had the alternator retested on and off the van (13-14 volts under load) so no problen there. fuses all check out, battery still holds a full charge only problem i have is the light stays on. Is there a fuseable link somewhere i need th check. any ideas would be a great help.
thanks
Vince
1999 ford windstar 100000 miles 3.8 engine
Jan 18, 2007 at 6:08 AM
SERVICE WRITER
  • 9,123 POSTS
There is a main wiring harness that rots out on these. It's a bear to get to as it is on the firewall side of the motor. This harness runs side to side and cause multiple electrical headaches. Access it, open it up and take a look.
Jan 18, 2007 at 8:46 AM
VGOOSE
[quote:f19bb554a9="Service Writer"]There is a main wiring harness that rots out on these. It's a bear to get to as it is on the firewall side of the motor. This harness runs side to side and cause multiple electrical headaches. Access it, open it up and take a look.[/quote:f19bb554a9]
thanks my next move was to trace the wires anyway so i guess thats what i will have to do
Vince
Jan 18, 2007 at 10:19 AM
Suggested Repair
Inspect the main wiring harness on the firewall side of the engine. It runs side to side and commonly rots, causing electrical problems including a battery warning light that stays on. Open the harness and check the wiring.
Conversation Summary
After replacing the alternator and battery on a 1999 Ford Windstar, the battery warning light stayed on. The alternator tested at 13-14 volts under load, fuses checked out, and the battery held a charge. The expert said the main wiring harness on the firewall side of the engine often rots and causes electrical issues, and advised opening it for inspection. The owner planned to trace the wires.
