2001 Ford Windstar Battery Light On
TODDP
i have a 2001 ford windstar with 80,000 miles when driving the battery light will come on i have hooked up a digital multimeter when light is on im getting 14.10 to 14.13 volts when i come to a stop the light goes out and sometimes the voltage will spike to 15.6 to 15.8 and then drops back to 14.10 to 14.13 it never goes below that unless im running all accesories i have cleaned all terminals and checked all connections
Sep 2, 2007 at 1:35 PM
  • 31,937 POSTS
Hi there,
I would be replacing the voltage regulator. 15+ volts is battery boiling country and other systems will struggle to cope with these high voltages, make sure the alternator is sound and battery terminals & earths are in good condition.
Mark (mhpautos)
May 4, 2021 at 10:24 AM
Suggested Repair
Replace the voltage regulator. Confirm the alternator is sound and that the battery terminals and grounds are in good condition, since voltage above 15V is excessive and can damage the battery and other systems.
Conversation Summary
The owner of a 2001 Ford Windstar reports the battery light comes on while driving. Voltage measures about 14.1V with the light on, and at a stop the light goes out while voltage sometimes spikes to 15.6-15.8V before returning to about 14.1V. Terminals and connections were already cleaned. The expert recommends replacing the voltage regulator, confirming the alternator is sound, and checking battery terminals and grounds.
