1997 Ford Windstar Battery CCA
ALDO
  • 5 POSTS
I wolud like to know how does it affect my car having an 850 cranking amps battery while the original was 650. The car is a 1997 ford windstar 3.8L and have a milleage of 144400.
Oct 2, 2007 at 10:03 AM
  • 75,988 POSTS
650 amps is how many CCAs your vehicle needs for reliable cold weather starting. The replacement battery should have the same or higher CCA rating as the original battery. Bigger is usually better, but keep in mind that some batteries sacrifice "reserve capacity" to achieve higher CCA numbers.
Oct 2, 2007 at 10:23 AM
BOOTDOG
  • 665 POSTS
i agree with raz!! as long as you have the same group battery, the more CCA's the better!! you don't wanna cheap lower CCA battery that has a warranty for a year so you can replace in 6 months. go bigger and better!!! remember.... you get what you pay for. good luck my friend!!! 8) 8) 8)
Oct 2, 2007 at 1:42 PM
ALDO
  • 5 POSTS
thanks and good luck to you too.
Oct 3, 2007 at 3:40 AM
Suggested Repair
Use a battery of the same group size with CCA equal to or higher than the original 650. An 850 CCA battery is generally fine and better for cold starts, but confirm reserve capacity was not reduced to raise the CCA rating.
Conversation Summary
The owner of a 1997 Ford Windstar 3.8L asked whether installing an 850 CCA battery instead of the original 650 CCA battery would affect the vehicle. Experts said the vehicle needs about 650 CCA for reliable cold starting and that a same-group replacement with equal or higher CCA is appropriate. They noted higher CCA is usually better, but some batteries trade away reserve capacity to achieve higher CCA numbers, and advised avoiding a cheap low-CCA battery.
