1988 Ford Tempo
BARRYLHUGHES
  • 1988 FORD TEMPO
  • 4 CYL
  • 123,000 MILES
MY PROBLEM IS MY CAR WILL RUN FOR A WHILE THEN IT QUITS. WHEN IT QUITS THEIR IS NO FIRE FROM THE COIL TO THE PLUGS. I HAVE ALREADY CHANGED THE COIL THE TFI MODULE AND CLEANED THE MAIN GROUNDS. THE CAR WILL START AFTER EVERYTHING COOLS OFF. WHAT IS YOUR ADVISE.
Wednesday, April 9th, 2008 AT 7:01 PM
SERVICE WRITER
  • 9,123 POSTS
What brand of Module did you use? Sounds like classic module problem. Maybe a new defect?
We have had to do some strange things to confirm the hot soak problems like making a component cold as quickly as possible or when it does start, try heating up a component with a hair dryer to see if it won't start when the r and r is too long to do.
Wednesday, April 9th, 2008 AT 7:24 PM
