2001 Ford Taurus P0401 EGR Code
DEEDEE1963
My 2001 Ford Taurus has 90,000 miles on it.It has the 3.0 engine.The service engine soon light came on about 6 months ago.The code revealed the EGR was defective.I replaced the EGR and the light came on again.I have since replaced all 3 componants to the EGR and the light still puts up a code PO401.Could someone please tell me what is causing this?
The ports and hoses were checked for blockage and none were found.
Feb 20, 2007 at 11:28 AM
NOS
  • 320 POSTS
at this point i'am goin to say that the code says no flow detected. the port on the intake maniflold is blocked with carbon. clean that hole real good and see if that don't fix your problem. some times the little rubber hoses also get pluged where that connect to the DPFE sensor also make sure there clean and free. 8) hope this helps NOS.
https://images.2carpros.com/forum/automotive_pictures/10147_6796170R10051_1.jpg
this is me and my dog after a hard day of working on cars i have done it for 23 years
Feb 20, 2007 at 11:51 AM
Suggested Repair
Clean carbon from the EGR port in the intake manifold and clear the small rubber hoses that connect to the DPFE sensor, then recheck for P0401.
Conversation Summary
A 2001 Ford Taurus 3.0 with about 90,000 miles has a service engine soon light and code P0401 after the EGR and all three related components were replaced. Ports and hoses were already checked and no blockage was found. The expert says P0401 indicates no EGR flow and recommends thoroughly cleaning carbon from the intake manifold EGR port and the small hoses at the DPFE sensor.
