1994 Ford Taurus Codes Without CEL
JAKIN
  • 16 POSTS
I have a 94 Taurus 3.0 with 144,000 miles. I do not have a scan tool, but I stopped in at my local Advance Auto Parts store to have them scan for codes. I was told that it was useless to run a scan if no engine light is showing since it wouldn't give them any codes. I was under the impression that there still could be some codes to read even though the engine light is not on or am I worng? Any advice would be greatly appreciated.
Jul 11, 2006 at 4:16 PM
TAURUSWHEEL
  • 718 POSTS
Trans codes can be in the continous memory and not show up as check engine light,, also there can be koer, key on engine running codes, that will not set the check engine light,, buy yourself the scan tool for your car, eec4 system,, costs around 30 bucks, easy to use plus there are a couple of other tests you can run using it
Jul 12, 2006 at 11:12 AM
JAKIN
  • 16 POSTS
I will put the scan tool on my wish list when I have enough money for it, thanks.
Jul 17, 2006 at 5:05 AM
Suggested Repair
Use an EEC-IV scan tool to check continuous-memory and key-on engine-running codes even if the check engine light is off. Transmission codes may be stored without illuminating the light.
Conversation Summary
The owner of a 1994 Ford Taurus asked whether a scan tool can retrieve codes when the check engine light is off. An expert said continuous-memory transmission codes and key-on engine-running codes may be present without the light, and recommended an inexpensive EEC-IV scan tool that can also run other tests. The owner planned to buy one later.
