2001 Ford Taurus EGR Code Returns
EO_WICCANANGEL
Recently I replaced the EGR valve in my 2001 ford taurus because the light came on and the computer said that was the problem. I then unhooked the battery to reset the light but it came back on. I took it back to have the computer test at shucks and it still says its the EGR valve! The car still runs funny(jerky and lacking power) and I am about fed up. Any ideas? :evil:
Nov 14, 2006 at 2:07 PM
BACKYARDMECHANIC
  • 337 POSTS
Hi
Did the shop clear the code after making the repair. If they did and the light came back on then, the EGR value probably wasn't bad to begin with. There is however something effecting it and preventing it from operating correctly. I'am not too familar with your car but there is probably a electrically solenoid that operates the value. This may be a place to start looking. There are also vacuum lines that are connect to the EGR value and should also be checked. Hope this helps.
Backyardmechanic :)
Nov 15, 2006 at 1:13 AM
Suggested Repair
If the code returned after it was cleared, the EGR valve may not have been the root cause. Check the electrical solenoid that operates the EGR valve and inspect the vacuum lines connected to it.
Conversation Summary
The owner of a 2001 Ford Taurus replaced the EGR valve after a check-engine code, disconnected the battery to reset the light, and still has the EGR code plus jerky running and lack of power. The expert said a returning code means something else may be preventing the EGR from working and suggested checking the operating solenoid and vacuum lines.
