1999 Ford Taurus Humming Noise
MOUNTIEJOE
My '99 Taurus, 115k miles, 3.0L makes a loud humming sound from about 35mpg and higher. The tire tread is OK & they are inflated properly. Any ideas?
Oct 2, 2007 at 8:34 AM
MERLIN2021
  • 17,250 POSTS
Not just an Idea...an answer! You have a worn front wheel bearing...part about 80.00, labor 150? Try driving it and turning the wheel slightly right and left, it should quite down a lttle, usually the left goes first..have it checked by a good mechanic and they can jack the car and check for play in the wheels...the loose one is the noisy one!
Oct 2, 2007 at 9:15 AM
Suggested Repair
Have a mechanic check the front wheel bearings for play, especially the left side. A worn front wheel bearing is the likely cause; the part is about $80 and labor about $150. Turning the wheel slightly left or right while driving may briefly quiet the hum.
Conversation Summary
A 1999 Ford Taurus with 115,000 miles and a 3.0L engine makes a loud humming sound from about 35 mph upward. The tires have adequate tread and are properly inflated. The expert says a worn front wheel bearing is the cause, usually the left one first, and recommends a mechanic jack the car and check the wheels for play.
