2002 Ford Taurus Engine Chirp
KOCHANHS
  • 25 POSTS
I have a 2002 Ford Taurus SES 67,000 miles. A few weeks ago, I hear this awful loud squeaking noise from the engine. I hear it on the driver side. Once the car is warmed up, it becomes loud chirping noises. I took the car to Midas and they said I need to replace the idler pulley and serpentine belt. They replaced them and cost me $230 and the noises are still there! I feel that I am being taken advantage of since I am a female who they think don't know anything.
Please help!
Thanks in advance.
Dec 12, 2006 at 2:04 AM
CATCH_15
  • 250 POSTS
Usually, a squeaking/chirping noise IS a bad idler pulley. As far as it costing over $200 to replace, that's ricdiculous. Another thing that could cause a chirping noise could be worn out bearings in the alternator. If you know what the alternator is, try listening to it close and see if that's where the noise is coming from.
Dec 12, 2006 at 3:11 AM
KOCHANHS
  • 25 POSTS
Thank you for replying to my inquiry on Squeaking/Chirping Noises from Engine. I will inform the repair shop to look into the bearings in the alternator since I had the idler pulley and the serpentine belt replaced. Thank you so much, hopefully this will end my endless nights of sleep.
Yes, they did charge me a little over $230 for the idler pulley and the serpentine belt replacements. I knew I got ripped off the first moment I stepped into the shop.
Dec 12, 2006 at 3:17 AM
Suggested Repair
With the idler pulley and serpentine belt already replaced, listen closely at the alternator. Worn alternator bearings can cause the remaining squeak or chirp and may need alternator service or replacement.
Conversation Summary
A 2002 Ford Taurus with about 67,000 miles developed a loud squeak on the driver side that became a chirp after warm-up. A shop replaced the idler pulley and serpentine belt for a little over $230, but the noise continued. The expert said that cost was excessive and suggested listening near the alternator, since worn bearings can cause the same chirp. The owner planned to have the shop check the alternator bearings.
