2005 Ford Taurus chirping noise
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
TYRI471
109,000 i have replace os front one plugs wires
Feb 7, 2010 at 10:33 PM
2CARPRO JACK
  • 11,533 POSTS
It makes a chirping noise? I couldnt gather much from your post, only the title.You replaced the wires? hows the drive belt look? if any cracks or shiny, replace it.If noise is coming from trans area( distributor-back of engine), you may have a Cam Position Sensor housing going bad, the bushings in them went away and would chirp like a bad belt
Feb 7, 2010 at 11:59 PM
