1995 Ford Taurus Whining Off Throttle
BEEBEEBEE
My Taurus GL is 1995, since last week, it started whining when I removed my foot from gas pedal, until it slowed quite down. Also whenever I step gas pedal even a little bit,the whinning goes away.Anyone knows this problem?Any information is appreciated.
Apr 20, 2007 at 3:04 PM
GARFIELD
  • 197 POSTS
First thing I would suggest to try is to go to the auto parts store and get a can of belt dressing. Spray it on the belt and see if the noise goes away. If it does it means that your belt is worn out and needs replacement. If it doesn't go away then you probably have an accessory drive that is starting to go bad. Try turning on alot of electrical stuff and see if the squeeling gets worse, if so it is the alternator going bad. Next pull your belt off and try turning different accessories to see if anyone of them has play or is worn out, don't forget to check your idler pulley and belt tensioner pulleys since they have small bearings in them that do go bad. Replace any of them that may be questionalble. Good luck.
Gary
Apr 21, 2007 at 3:05 AM
BEEBEEBEE
Your suggestions are really reasonable. I will try them and glad to lat you know my findings
Apr 21, 2007 at 3:27 AM
Suggested Repair
Spray belt dressing on the drive belt. If the whine stops, replace the worn belt. If it continues, load the electrical system to check the alternator, then remove the belt and inspect the accessories, idler pulley, and tensioner for play or wear and replace any questionable parts.
Conversation Summary
A 1995 Ford Taurus GL began whining when the driver lifted off the gas until the car slowed, and the noise stopped when the accelerator was pressed. The expert recommended a belt-dressing test, then checking the alternator under electrical load and inspecting accessory, idler, and tensioner pulleys for wear. The owner planned to try those checks.
